too much power 4 MM12?
Coconut Banger
I BOUGHT A RF 551S POWER AMP FOR MY MM12 AND WAS WONDERING IF THE EXTRA 50 WATTS RMS PUMPING OUT OF MY AMP MAY BE ENDANGERING THE SUB. I'VE HEARD THAT MORE POWER IS ALWAYS BETTER THAN LESS POWER, BUT IN MY CASE IS IT HAZARDOUS TO THE SUB? AND IF POSSIBLE COULD I CUT DOWN ON THE EXTRA WATTAGE BY CHOICE OF WIRING?
jP
Post edited by Coconut Banger on
I HAVE BOTH OF MY SUBS RUNNING OFF OF 2 550S'--NO THE EXTRA POWER SHOULD NOT HURT YOUR SUBS--IT WOULD NOT BE A BAD IDEA TO KEEP THE GAIN DOWN A LITTLE THOUGH
-CODYMusic is like candy, you have to get rid of the rappers to enjoy it -
BUT KEEP IN MIND THAT CODY HAS BLOWN A HALF DOZEN SUBS BY RUNNING AN EXTRA 50 WATTS TO EACH OF THEM. PLUS THERE ARE ABOUT 50 DIFFERENT POSTS ON HERE CONCERNING MOMO SUBS THAT KEEP ASSUMING ROOM TEMPERATURE WITH VERY LITTLE OVER THEIR MAX RATING.
WHY ARE WE YELLING?polkaudio sound quality competitor since 2005
EXACTLY--THATS WHY YOU SHOULD TURN YOUR GAINS DOWN, AND MORE IMPORTANTLY, BREAK THEM IN FOR 40 HOURS
I HAVE NO IDEA WHY WE ARE YELLING
Actually if you listen to rap or hip hop then it may be ok. Me and Cody listen primarily to metal and hard rock which has constant heavy kickdrums, bass lines and mid bass and is really hard on amps and subs cause it doesnt let up much and amps tend to run a lot hotter. Rap has very hard hitting bass lines but they also have pretty long pauses in between and gives the amp and sub a chance to catch its breath.polkaudio sound quality competitor since 2005
actually when i listen to hip hop it hits a lot harder and a lot longer than rock
whenever i stop at a light the voltage goes down to 12 and doesnt come back up until i get going again...
weak **** alternator...
True, but usually hip hop only has that one bass note that is usually BOOOOOOOOOM........BOOOOOOOOOOOM.......BOOOOOOOOOOM.
Heavy metal is hitting all over the frequency range and it doesnt let up. The kick drum is pounding thru the entire song, the bass guitar is playing as fast as the lead guitar and the guitar itself has a good bit of midbass hittin' going on.
I loathe rap but I dont like some techno and my spunky little Crossfire VR302 is way hotter after a good Slayer album than a Paul Oakenfold.
Im assuming that whats hardest on the sub amp will also be hardest on the sub itself.polkaudio sound quality competitor since 2005
my amps are hot either way...
on my last pair of subs itd smell like they were burning though when i cranked up some hip hop
turned the gain down and they still blew
huh... i'm only running the mm6's off a 300.2, but it's usually at maximum performance (i drive a convertible... can we say background noise??) and my amp never gets hot... i take 3 hour drives on a regular basis, and it's always cool to the touch...It's not good, very fundamentally simply not good. - geolemon
My Crossfires are usually only slightly warm. I play mine pretty stout for extended periods and they stay cooler than my previous Alpines. However Ive got mine set up to where they get plenty of cooling.polkaudio sound quality competitor since 2005
