How much power???
DesertPilot
DesertPilot Posts: 57
edited September 2004 in Electronics
I'm sure you get this question all the time. But, what the heck. Here's my setup. I'd like to upgrade my amp but could use some advice on how much power would be adequate.
room is rectangle, 19' wide by 21' long.
Primarily home theater (DVD movies) viewing (lengthwise). But play a fair amount of music at moderate listening levels.
left and right speakers are RTi6
center is CSi5
rear left/right surrounds are RTi6
two PSW505 subs, on the floor, under the rear surrounds
Currently, I am using a Denon 1804 (90 watts per channel).
Everything I read on this forum suggests that this is not enough power. So what are your thoughts?
super appreciate your input.
Marcus
LSi9 + LSiC + LSiFx
dual PSW 505
Integra DHC 80.2 Pre-Amp
Outlaw 755 Amp
OPPO BDP-93 universal player
BENQ W6000 Projector
Da-Lite120 inch diag screen.
BlueJeans Cables all around.
Post edited by DesertPilot on
  • Toxis
    Toxis Posts: 5,116
    Are you happy with the sound/output?
  • Early B.
    Early B. Posts: 7,900
    You have a nice setup. The 1804 should be plenty of power for the RTi6's, especially at moderate listening levels as you indicated.
    "God grooves with tubes."
  • DesertPilot
    Oh yes, I am happy with the sound. And I wish I could try my speakers with a more powerful amp just to find out if I can hear a dfference.
    I'm kind of waiting on another amp for two reasons:
    1) I'd like a DVI/HDMI interface through the receiver. I really like being able to switch video sources and sound sources through the receiver.
    2) And I want to take a look at the new computers that offer Windows XP multi media since I am using downloaded music a lot.
    thx...Marcus
    LSi9 + LSiC + LSiFx
    dual PSW 505
    Outlaw 755 Amp
  • PolknPepsi
    PolknPepsi Posts: 781
    Hi,
    I have always used a reciever for music. (the last 15-20 years)
    Looking to get an amplifier to play with, use my reciever as a pre.
    Just my wife in our house and mostly music/with a little movie watching on the weekends. For my use the 150-250 watts per channel is what I have been checking into. It just brings out the instruments and makes things sound more real if that makes sense. With all that power I just won't get silly with the volume and everything will be ok.
    :) ................Pat
    Denon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's
    F1nut Posts: 50,761
    Marcus,
    It sounds like you're not really looking for a new amp, but a new receiver. Don't confuse the two because they are different animals. Getting a new receiver with, say 150 wpc isn't going to be much different than what you have now. Adding a seperate amp (if you can use the receiver as a pre), at say 150 wpc would make a difference that you'll hear although with downloaded music I think what you're going to hear is how bad it really is.
    Pat,
    I've got a nice Rotel amp in the flea market.
  • Airplay355
    Airplay355 Posts: 4,298
    i agree with f1
    why do you want a dvi input on the receiver? its better to go directly from the source to your tv, don't add your receiver in the loop.
    downloaded music can offer tolerable quality, sometimes. usually the bitrates are wrong and it sounds like crap. just buy the cd man lol.
  • HBombToo
    HBombToo Posts: 5,256
    I am there. my hk 520 is used as a pre/pro only. a seperate amp is the only way to go IMHO. I have an outlaw
    Twin
    ***WAREMTAE***
  • RuSsMaN
    RuSsMaN Posts: 17,986
    200-250 wpc should be enough. You could go 150-180 on the rears if you wanted to.
    Cheers,
    Russ
  • amulford
    amulford Posts: 5,020
    I'm w/ Russ. 200 WPC on the front. You could go less on the rears, unless you plan to listen to a lot of multi channel music. I think you'll find the downloads stink w/ more power, though...
  • DesertPilot
    WOW! Thanks everyone for all the replies. You're kind of leading me to the same conclusion. Use my receiver as a pre and simply get a more powerful amp. 200wpc sounds about right.
    Gosh...the more I get in to this...the more I want. hahaha.
    Marcus
    LSi9 + LSiC + LSiFx
    dual PSW 505
    Outlaw 755 Amp
  • amulford
    Yeah, tell me about it...;)
