One more amp question on MM465
Systems
Systems Posts: 14,872
edited February 2002 in Car Audio & Electronics
Just wondering how I should hook up my MM465s.
I have an MTX Thunder 304 right now.
Should I bridge the the 4channels into 2, and run the 6.5s off the two channels, or leave it 4 channel and run the 6.5s.
In two channel that amp will put out about 200W, in 4 channel about 67-90W RMS(from the rating it came with from MTX).
Testing
Testing
Testing
  • uberfreix
    uberfreix Posts: 15
    I would run it in 4 ch mode. The high your impedance rating the better sound you will get and 75 watts will make any component play just fine. I would consdier 3 channel...bridge rear 2 channels and add a sub. The would be a good compromise to the question in previous post. Ocne again hope I helped
    Matt
