good cutting tool suggestions? for metal
faster100
Ive replaced now the stock power cords on my tosh 3960 and yesterday on my fisher tuner, as i move into more pricey gear i want a good cutting tool to use for like my pre, amp and maybe some day the dynaco... i have a dremel tool ... what blades should i use? The thin carbon wheels always burn away before doing much cutting, any idea's or suggestions.... Ive always been into making things and projects and this really interests me.. so i want the right tools for the job for a clean look. so far ive just made due,
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
Post edited by faster100 on
anyone?MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
Dremel makes a carbide tip or maybe several by this time that will remove quite a bit of metal and they don't wear out. You have to be careful as they will load up if you use them on softer metal such as aluminum. You can also get a die-grinder which is a grown up dremel tool. Small hole saws can also work well with an electric drill if you are careful. A special bit made of carbide is available for die-grinders (1/4 inch shank) with very open flutes fro use on soft metal.
Good luck, Phil -
Here are two articles that describe exactly what you are doing. The first article has a picture & description of the tool the author used to cut away the metal when he added and IEC receptacle for a power cord upgrade.
http://www.soundstage.com/maxdb/maxdb200006.htm
http://www.soundstage.com/maxdb/maxdb200007.htm
Enjoy.Bob Mayo, on the keyboards. Bob Mayo. -
Have you check the computer case mod sites? They talk about this stuff a lot. I haven't really paid much attention to them as I haven't got the bug yet.
Good luck
DaveTime is the best teacher. Unfortunately it kills all its students. -
hey thanks, I knew someone could find something that i could not,MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC
