XLR ? I don't have a clue!
gwh
Bought some gear off Ebay ,due to arrive next week.
Art 351 eq and a QSC amp.
Want to connect the two with the xlr inputs/outputs.
Ive never messed with xlr cables. Need to know if both ends need to be
male or female, or one male and one female.(Ill only be using one cable, mono config)
Thanks,
G
Thanks,
G
HT:
Martin Logan Motion 40
Martin Logan Motion 50XT
Emotiva Airmotiv E2
SVS SB16 Ultra
Def Tech Reference Sub
Yamaha RX-A3070
Signal Cable speaker wires & interconnects.
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Post edited by gwh on
XLR cables are not needed if you are setting up the amp and pre-amp close to each other. XLR cables are great if you have a huge distance to cover, but standard RCA-type connectors are perfect for shorter distances. Save your money.
Thanks Frank,
The amp has xlr or 1/4 trs inputs only.
Should I get a RCA to XLR adapter?
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Signal Cable speaker wires & interconnects. -
Originally posted by gwh
1/4 trs inputs only. -
Thanks for the help.
GHT:
Emotiva Airmotiv E2
SVS SB16 Ultra
Yamaha RX-A3070
Your very welcome!!
I would prefer XLR over RCA. XLRs are much better at rejecting noise (which shouldn't be a huge problem, if a problem at all in home). If you're worried about price, musiciansfriend.com has XLRs that are priced for the budget consumer. I believe Hosa (that's a company to search for) generally has the least expensive cables.Brian Knauss
ex-Electrical Engineer for Polk
