DVD player no Macrovision
daslolo
daslolo Posts: 7
edited September 2004 in Electronics
I have been told that when a DVD player is connected vis S-video THROUGH the receiver, the image flutters slightly because Macrovision kicks in.
Any confirmation on this one and what can be done (beside direct connect which is not an option)
Thanks.
Post edited by daslolo on
  • madmax
    madmax Posts: 12,434
    Even direct connection has this issue. There are people out there on the internet who make a little box which removes the macrovision problem. They make it not to remove the macrovision for the intended purpose of recording but to allow reproduction of the video image on projectors and the like. Yea right... I've heard that even best buys sells one but I have not looked for one. If you cannot find one let me know via pm. It is my understanding they sell for $50 to $75.
    madmax
    Vinyl, the final frontier...
  • daslolo
    daslolo Posts: 7
    What a mess, and by adding a box you loose what generation of signal off course... is there a digital way to remove macro at the DVD decoding level then ?
  • kingtut
    kingtut Posts: 813
    I have a Panasonic DVD player, connecting to a Denon 3803 w/S-video. No problem w/image fluttering. I also have an older and cheapie Apex DVD player, which firmware can be downloaded to defeat the macrovision feature.
  • Willow
    Willow Posts: 11,256
    I have a marantz as my main dvd player no problems as well as my second dvd player a toshiba never seen this problem
  • phoneisbusy
    phoneisbusy Posts: 867
    Some dvd players have hacks for turning off region coding and macrovision. The ability to turn off macrovision seems to be mostly found in the low end players though (e.g. apparently the philips 642 comes with analog macrovision off. Plays divx too!).
    Don't know if this is an option for you or not.
    regards
    Dave
    Time is the best teacher. Unfortunately it kills all its students.
