Polk RM 6700 + PSW303
sudhirbhan
Hi all,
I am a newbie to the world of home theater systems. Though I have owned 3 different stereo systems (all Sony) till date, this is the first time I would be venturing into the hometheater zone.
I am interested in a 5.1 set up that consists Polk RM6700 and PSW303. The receiver that I have in mind is Onkyo TX-SR502.
Music:Movie ratio would be approx 5:3. The dimensions of my room are 15 * 20 * 9.
Could y'all gurus please give me some advice on the above configuration?
Thanks in advance,
Sudhir
Thanks in advance,
Sudhir
Thanks for ur reply anonymouse! My budget hovers around 1000 USD, give or take a hundred.
For movies, the RMs would perform adequately. Your ratio of music is a concern. My ratio is more the oposite music:movie=2:5, but I still went with separates. The reason being is the small satellites generally have cut-offs leaving holes usually in the 80-100Hz range. Subs go 80Hz and down. Not sure what the lower end of the RM 6700 satellites is.
I suggest going with at least bookshelf fronts: say RTi6 with center CSi3 with RTi4 surround. Then you just add a decent sub, such as HSU or SVS. Set all speakers to small, and crossover at 80Hz. I might have pushed you over budget though. In which case start with the fronts, center, and sub, and add the surrounds later. Crutchfield has some good prices on the polks wth free shipping and no tax. And HSU is selling b-stock VTF-2 at a discount or you could pick up the STF-2 or wait for the SVS 10-ISD
I initially ordered the RM6700 with the free 202 sub; and returned everything; and decided to spend a bit more. Now I'm very happy and won't need to upgrade for some time. My system:
HK AVR 430 in 7.1:
RTi8 (front)
CSi3 (center)
FXi3 (surround)
RTi4 (rears)
The warmth of the of HK is perfect match for the RT series. Good luckOriginally posted by sudhirbhan
Hi all,
Thanks in advance,
Sudhir
