Fxi5 HELP. Base measurements
Since Polk has not gotten back to me in time for my weekend construction I really need your help. Can someone please take measurements on the bottom/base dimensions of their Fxi5's so I can build speaker stands to fit their odd shape? I need the every measurement inclucing the little length in the front. So to give you a clear I dea of what I need I need the meausrements of the bottom of the speaker soI can cut and match a peice of wood to make a stand for the speaker.
If you can take the time to do this I would greatly appreciate it.
Sorry, man, don't know the dimensions. But why not wall mount them? That's what they're primarily designed for, and where they will sound the best.Current System:
CSi5-Center (for sale**)
FXi3-surrounds (for sale**)
Martin Logan Depth-Sub
B&K AVR 507
Pimare CD21-CD Player
Denon 1815-DVD Player
Panamax M5500-EX-Line Conditioner -
11 3/4 inches wide, about 8 in deep. Flat side in front is 2 1/2 inches. The back side corners come up about 2 inches before they angle towards the front to make the triangular shape.
11 3/4
8
-2 1/2- -
Thanks. Let the construction begin. Just as a not for people. I bought all the wood, stain and screws at home depot and it only came to 36$. May be a nice alternative to $100 speaker stands. I am staining them "onyx". try to let you know how it comes out.
You may want to look at this thread :
http://clubpolk.polkaudio.com/forum/showthread.php?threadid=21586
Niiiiice !!!
SDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more
