AMR90 and Soundblaster Live "Value"
spinningimage
I just hooked up these speakers but I can't get the rear set to work. Does the SB Live "Value" card support surround sound? If so, what should I be checking to see that I have set this up properly? Thanks.
Post edited by spinningimage on
Yes, the Live! Value supports surround sound. You need to make sure that you have the Live! card set to 4 speaker mode, and make sure all your connections are correct on the rear of the soundcard.LSi 9/C/FX
Arcam AVR-200
