sanity check my configs
Euthyphro
Euthyphro Posts: 4
Just wanted a sanity check on my configuration settings.
H/K AVR 430
L/R: RTi8 (small, X-over set to 60Hz)
Center: CSi3 (small, x-over set to 80)
Surrounds: RTi4 (small, x-over set to 80)
Sub: HSU VTF-2, set to base extension (LFE, x-over set to "same as surrounds")
Use: 80% DVD, HDTV, SDTV; 20% Music
Are my above settings reasonable, or should I also set the RTi8 to x-over at 80Hz to keep them same as center and surrounds?
Alternatively, based on the specs, I suppose I could go 20Hz lower also on all channels.
thanks.
Post edited by Euthyphro on
  • Early B.
    Early B. Posts: 7,900
    edited August 2004
    Nice setup. Gotta love that Hsu, don't ya?
    I'd set the x-over at 80 for the 8's.
    Have you calibrated your system yet using a DVD test disk (i.e., Avia) and SPL meter?
    "God grooves with tubes."
  • Euthyphro
    Euthyphro Posts: 4
    edited August 2004
    Thanks. I realize I have a modest configuration, but it works well is my modest 13x18 media room.
    Guess, there's not much benefit it lowering the xover for the 8's to 60Hz (it's -3db limit doesn't kick in until about 40Hz; that's why I was asking)?
    The Avia disk is supposedly "in the mail", and I've got my sound meter prepared once it arrives.
