fxi3 vs. fx300i
My local Circuit City has fxi3 on clearance for $199.99 and Crutchfield has fx300i (white only) for the same price. How does the fxi3 compare to the fx300i? How would either match with RT55 fronts and a CS300 center?
I would think the 300's would be a closer match to what you have up front. However it isn't real important the the surrounds be an exact match and the 3's will be close enough. As far as the differences go you can view the specs for each in the home products section.
