New Power Protection from PS Audio
F1nut
F1nut Posts: 51,789
edited August 2004 in Electronics
Post edited by F1nut on
  • dorokusai
    dorokusai Posts: 25,576
    edited August 2004
    It looks like a market response to the Richard Gray 400MKII, and the theory he uses in non-current limiting gear....the likes of which PS Audio hasn't done until this thing. 4 Outlets, no current limiting circuitry, power conditioning...hmm sounds familiar.
    It's prettier than the RG, and suprisingly not super over-priced like most PS Audio gear....I would buy whichever one I found cheaper.
  • gregure
    gregure Posts: 871
    edited August 2004
    Couple of questions re: power centers. Looking over literature on Richard Gray, BPC and this new PS Audio device, I see references to 20 amp circuits. Aren't 15 amp circuits the norm in most households? That said, do these units create a 20 amp circuit for the units they feed, or do they need to be plugged into a 20 amp circuit? In other words, do these things work on standard 120 volt outlets or does one need to upgrade their home power circuits? Thanks.
    Current System:
    CSi5-Center (for sale**)
    FXi3-surrounds (for sale**)
    Martin Logan Depth-Sub
    B&K AVR 507
    Pimare CD21-CD Player
    Denon 1815-DVD Player
    Panamax M5500-EX-Line Conditioner
    F1nut Posts: 51,789
    edited August 2004
    15 amp lines are the most common, but you will find 20 amp and 30 amp or more lines in a house all running 120 volts. The units can not make a 15 amp line into a 20 amp line, but if you only have a 15 amp line there is no reason you can't use one of these units on it. One reason they come rated to handle 20 amps is that many people when adding a dedicated line for their gear get a 20 amp line put in. Another reason is that some gear requires more than 15 amps. In short, they will work just fine with your current 15 amp line.
  • scottvamp
    scottvamp Posts: 3,277
    edited August 2004
    Say i'm running all my HT electronics on my monster power unit, I am probably going to need a 20 amp over a 15 amp outlet. What is the easy way to tell what the outlet is capable of??? I am a newbie in regards to this. Maybe a wall tester............
    When I built my dedicated HT in my garage I ran a dedicated 20 amp for it. When I moved to another room my MP 3500 will go as low as 113 out of 120 with everything running including an in wall AC unit. I know this degrades sound and video.......
    Wondering how to avoid this with my new rental home.
  • dorokusai
    edited August 2004
    The outlet let's you do whatever you want, it's dependent on the breaker for that line. You could stick your fingers in it and it will create a 20+ amp condition.
    If you are experiencing that kind of drop, you should look into your wiring, make sure it's straight and 100%. Dedicated means dedicated...meaning single outlet to breaker, not 8 outlets to breaker.
  • PolkThug
    PolkThug Posts: 7,532
    edited August 2004
  • scottvamp
    edited August 2004
    WTF!!!!
    Like I said I had a dedicated 20 in my original HT room but for the rental how can I tell how many outlets to one breaker......
    I guess I could kill the power on the breaker and see what is shut down.....
  • dorokusai
    edited August 2004
    It was a joke Scott.
    Here is what you need to determine outlet to breaker continuity, and is always handy to have in the kit.
    Gardner Bender
    Home Depot carries the brand...any receptacle identifier will do, it's just a suggestion.
