R50 tower match
Tadziusix
Tadziusix Posts: 2
edited August 2004 in Speakers
Hi everyone, i have a set of R50's and a Csi3 center. Is this a good match or is it worth upgrading the 50's to Rti8's
  • stereo55
    stereo55 Posts: 418
    edited August 2004
    The RTi8's will definitly be a improvement over the R50's and a much better match for your CSi3 . The newer RTi line has a much improved tweeter and a cleaner , more depth sound compared to the R line . If you purchased your R's from CircuitCity , trade them in fast ; as the RTi line is/has being closed-out at CC . You maybe hard pressed to find any RTi 4/6/8/10/12's left at CC as they has discontined the RTi line at CC to make room for the new , but slightly lower-end Monitor series .
    SDA-2B's ~ Pair SDA-CRS's ~ ,*** Main listening: Maggies MG1 ~ Polk SDA 2B's ~ Monitor 10's , 3-pairs (2 pairs moded into SDA's w/SDA-2B/CRS cross-overs) , * DCM TF600's * Mission M71/M72 *** Main brdrm FRT: RTiA-5's /Presence RTi-4 / LSI-704 Cntr / Rear FXI3's ~~~ Assorted Main listening rm : , 2- Heathkit W-5M /tube mono blocks (Parasound P/HP-850)* * 2- Altec Lansing 1590b's/mono blocks (Yamaha C-45) * CM Labs 35D * Dynaco ST-70 ~ Occasionally ~* Yamaha CR-820/A-760 ,* Sansui AU-317/AU-217 * Carver 900 rec *2-Dynaco ST 120* 1 Hafler DH-220* Marantz 1040 ... more
  • Tadziusix
    Tadziusix Posts: 2
    edited August 2004
    Thanks for the tip, going to go buy the 8's today. Thanks Matt
