Momo
Wicked2049
Wicked2049 Posts: 2
edited February 2002 in Car Audio & Electronics
Hello,
My name is Guy Frick and I am from Pierre, SD. I recently purchased two of your Polk Momo MM120 subwoofers. I installed them and one makes a popping/tapping noise. It sound like there is something tapping the red center cap. Do you have any ideas on what this may be? I never had the volume that high and the gain on my amps were never higher than half of the amps maximum setting.
My other question is, does the sealed box volume make that big of a difference in sound quality, or could it eventually hurt the sub or affect its performance?
Post edited by Wicked2049 on
  • Systems
    Systems Posts: 14,872
    You sure its the dust cap? Other people have had the same problem (2-3). Someone said before (I think) that the voice coil came unglued. Or it could be around the woofers mouting flange. Make sure u have it sealed tight.
    Testing
    Testing
    Testing
  • Wicked2049
    Wicked2049 Posts: 2
    i was reading on your page about box building for the momo, it says you add fill.. doesn't that make the box "bigger"? and i will send them out as soon as i get paid, thank you
