Atrium 55
bigyank
bigyank Posts: 224
edited April 2005 in Speakers
Purchased a pair of these for bedroom speakers! Driving them with a Sansui AU-G99X (160 watt/ch) integrated! Mounted the speakers about 7 feet up on the walls 16 feet apart and corner mounted (wife acceptance factor seems to be okay as well).
These are my first pair of Polk speakers and I have to say right out of the box these sound wonderful.
Yank
Polk Monitor 7
Polk Atrium 55
Post edited by bigyank on
  • trubluluc
    trubluluc Posts: 2,067
    edited August 2004
    Indoor/outdoor speakers in the bedroom huh?
    Yes I have a pair on the deck, pretty decent.
    -Luc
    VR3 Posts: 29,549
    edited August 2004
    In a month they will be totally different speakers.
    If you think they sound good NOW, just wait till they break in!
    They are AWESOME lil speakers.
  • gatemplin
    gatemplin Posts: 1,595
    edited August 2004
    Welcome to CP,
    Nice amp, have you seen this.
    Graham
  • bigyank
    bigyank Posts: 224
    edited August 2004
    Yes I have thanks! I have original manuals, boxes, etc as well. I am still so pleased at how well the amp (and I also have the matching tuner the TU-D99X as well) mate.
    Impressive forum here!
    :D
    Yank
    Polk Monitor 7
    Polk Atrium 55
  • fasteddie28
    fasteddie28 Posts: 1
    edited April 2005
    I've got my Atrium 55s mounted by patio horizontally. I cannot get the speakers to remain in the position I want. They keep flopping forward - I can only hand-tighten these so much. I've torqued them by hand as much as I can & it still doesn't seem tight enough. Anyone else have this prob? If so, got any tips or advice? Thanks.
  • Jstas
    Jstas Posts: 14,996
    edited April 2005
    If I remember correctly, You can remove th metal bracket from the mounting holes on the speaker case with a pair of screws. Get yourself some felt discs at the hardware store and sandwich them in between the metal bracket and the speaker and screw the bracket on again. This should provide enough friction to keep the speaker where you place it without damaging the speaker or bracket.
    Or you could call Polk customer service.
    Expert Moron Extraordinaire
