Anyone familiar with this...
steveinaz
Anyone familiar with the Marantz PMD-800 am/fm tuner? Here's a pic:
Post edited by steveinaz on
Alright....take a time-out mister.;)Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
Ok, FWIW I found some info. It's apparently the replacement for the ST6000P; in fact aside from model number, they are identical in appearance and spec's.Source: Bluesound Node 2i - Preamp/DAC: Benchmark DAC2 DX - Amp: Parasound Halo A21 - Speakers: MartinLogan Motion 60XTi - Shop Rig: Yamaha A-S501 Integrated - Shop Spkrs: Elac Debut 2.0 B5.2
If that tuner is anything like the one in my old Marantz reciever then it should pull in stations from far away!
..:) .....PatDenon #2900, Denon stereo receiver, Conrad Johnson Sonographe 120 amp, Blue Jeans cables, and Klipsch RF-7's -
From vintage tuners.
The ST6000/6000P is a current-model black AM-FM digital tuner that is available either with (the P model) or without rack-mount handles. We don't know if there are any other differences between the two versions. Like its competitor, the Fanfare FT-1A, the ST6000/6000P is very attractive and has wide and narrow IF bandwidth settings. It has the electronic equivalent of 4 gangs and 4 ceramic filters. Our panelist Eric reviewed an ST6000 that had been modified before he got it, so we can't say anything about it in stock form, but with narrow filters installed its selectivity is tough to beat. The ST6000 usually sells for $120-190 on eBay, but one clueless seller priced his Buy-it-Now at $45 in 12/03. [EF]
