is this what it says (wpc)
Willow
Willow Posts: 11,255
edited August 2004 in Electronics
is this really 100wpc ?
Stereo Power: 100 Watts per Channel (FTC, Left/Right, 40Hz - 20kHz, 0.7% THD, 8 ohms)
- Surround Power (Center): 100 Watts (40Hz - 20kHz, 0.7% THD, 8 ohms)
- Surround Power (Left/Right): 100 Watts + 100 Watts (40Hz - 20kHz, 0.7% THD, 8 ohms)
- Surround Power (LSurround/RSurround): 100 Watts + 100 Watts (40Hz - 20kHz, 0.7% THD, 8 ohms)
- Surround Power (Surround Back): 100 Watts (40Hz - 20kHz, 0.7% THD, 8 ohms)
thanks I don't know how to read this !!!
Post edited by Willow on
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2004
    I think this would be "sort of."
    It is assuming that one will be running a sub for the low frequencies. I've seen other posts about this. I figured they were running those ratings up a bit higher to like 60Hz.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited August 2004
    That's the whole idea ...
    It would be better if it said ...
    100 Watts per Channel 20Hz - 20kHz, 0.7% THD, 8 ohms, all channels driven.
  • RuSsMaN
    RuSsMaN Posts: 17,985
    edited August 2004
    At least they are honest.
    Judging from the specs, its a pretty low-budget receiver. Keep THD at .5% or lower (how much lower is irrelevant). Look for full range, ie 20Hz - 20Khz ratings.
    A lot of 'cheap' receivers massage the power ratings, but not including that last octave of bass, which is a power hog. I'd be willing to bet you won't get even 50 watts out of it.
    Cheers,
    Russ
  • Willow
    edited August 2004
    right it is a low end receiver, it's the kenwood in my bedroom system only powering to bookshelf JBLs but I never really thought it was 100wpc.
