6 ch input
Willow
Willow Posts: 11,283
when would I use this ? is this for SACD ?? Im talking about the input on the back of the receiver. I don't need to hook this up if I want to add a rear centre do I ??
Post edited by Willow on
  • gatemplin
    gatemplin Posts: 1,595
    edited August 2004
    It is used for SACD and DVD-A and any other format the receiver cannot decode or when you want to use the DACs in the player. I am not sure what you are asking about the rear center.
    Graham
  • Willow
    edited August 2004
    thanks gatemplin thats what I thought. about the rear centre I was asking if I needed to connect to the 6 ch input in order to get my 6.1..then it hit me I saw the rear center speaker cable binding post on the back of the receiver !!
  • gatemplin
    edited August 2004
    Yeah, you can still use the digital connections. The 6 channel input includes the sub, no dedicated rear center AFAIK.
    Graham
