to SL3000 or not to SL3000?
hvassef
hvassef Posts: 1
edited August 2004 in Speakers
[New to this forum - please direct me to the proper thread if this topic was previously discussed...]
Got a hold of a pair of used SRS 3.1 TL speakers. They are both missing their SL3000 tweeters.
Polk club is selling them for $64 a piece, but part of me thinks that it includes a vintage OEM premium - much like how if you were to buy, say for example, an OEM waterpump for a 1984 Ford Truck, you'd pay the original Ford OEM price even 20 years later, which is at least three to four times the price of an aftermarket part. For $64, there are a lot of seemingly high-quality tweeters out there.
So my question to you audiophiles: is the SL3000 worth it, and if so, why? How does it compare with modern tweeters in the $64 range?
If I'm to consider alternatives, what are the specs of the SL3000 (impedance, etc.), and what modern tweeters out there would be considered adequate replacements?
(Also, what would be the proper way of fitting and sealing an alternative replacement in the casing so as not to render the bass radiator useless? Perhaps I should take this work into account when pricing possible alternatives...)
I might need a bit of handholding with this. Truth is, I don't have a huge amount of experience with speakers, and while I did study it all at some point, my LRC knowledge is very rusty.
Any help would be appreciated.
  • hoosier21
    hoosier21 Posts: 4,437
    edited August 2004
    I would buy the new replacement tweeters Polk offers, call CS and tell them you are a member of the club and get discounted pricing.
    Dodd - Battery Preamp
    ADS 1230 - Polk SDA 2B
    Crown K1 - Subwoofer amp
    Outlaw ICBM - crossover
    Beringher BFD - sub eq
  • dorokusai
    dorokusai Posts: 25,661
    edited August 2004
    If you want original SL3000's, send a PM to "F1Nut" or he may respond later.
    The only worthy replacement, is a Polk replacement. The original or the replacement version are both outstanding. It's not worth the effort to modify the original design and application with an aftermarket tweeter array.
