Used RTi6, Floormodel
I got RTi6s at CC, but they could only give me the floormodel, thats a long story, I'll post that with the pictures. The one speaker, with the damage, has mostly comestic damage, I was wondering if you guys have any suggestions for how to mediate these problems.
1) One of the grille pegs broke off but can be glued back on, what glue would be best?
2) The woofer was overtightened, is there any hope there? It isn't bad. I'm gonna take another look tomorrow and post more info.
3) Also, the veneer has been bumped in, like a nick, but nothing was scratched, any suggestions on how to make this less noticable?
4) The silver faceplate is scuffed, right by the woofer, is there a way to paint, sand, polish it out?
5) Lastly, is goo gone safe on the Black oak veneer? They put a floor model sticker on the sides of the speaker and I want that gone pronto.
Thanks guys, your help is appreciated.
I would think super glue would do just fine....
In over-tightening, what happened? Did something crack? explain....
Jesse may be able to help u on this one....
Can u see it with the grill on? If not, leave the grill on - scuffs arnt coming out...
those adhesives are incredibly easy to get off, rub your fingers on it really fast, take a damp towl, it should come off....- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Don't waste your time if their in that bad of shape. Take 'em back and order a decent pair from Crutchfield, or even a NIB pair from ebay.
Thanks guys for your prompt responses, I got out my Hex set and loosened the screws on the woofer and retightened them, it worked liked a charm, sorry I wasn't specific on it. The surround looked like an overtightened drum, it had a creased look, the plastic ring wasn't cracked.
