Direct better ?
presidan
I've read a lot of posts here that suggest having direct speakers as surrounds instead of the bipole/dipole to listen to music in multichannel formats. Why is that ? And what about movies ?
RT2000i
F/X1000
CS400i
DENON AVR-3802
PIONEER PDP 4360-HD 43"
F/X1000
CS400i
DENON AVR-3802
Post edited by presidan on
Hi:
I think the posts have concluded that it is really a matter of preference, and what you want to accomplish in your setup.
Some like direct and some like indirect. It's all up to you.
Gary -
this is true... the last poster had it right.. it's all about what you like.
for example I have a very small TV room (12x14) so i decided to go with the FX/300i in bipole mode.. after trying some direct speakers.. i am very happy with the diffused surround I get from the surrounds. when i had the direct speakers hooked up.. the surround sound was to focused.... mostly because i could not place them far enough behind my sweet spot.PolkFest 2012, who's going>?
I opted to not get the direct firrings because my couch is all the against the wall. I also have alot more movies on VHS than on DVD. It works for me.Make it Funky!
