Should I bi-amp the Lsi15's
jrlouie
jrlouie Posts: 462
edited August 2004 in Speakers
I read a post earlier on another thread and wanted to get your opinions. I have an Onkyo TX-DS797 receiver and a seperate power amp all running my 6-channel surround setup. I currently have the Onkyo running LsiC, FXi30's, Csi30 (rear-center surround) and my power amp running the Lsi15's.
The other thread I read suggested bi-amping the Lsi15's using the power amp for the lows and the Onkyo for the highs while still using the Onkyo for the other 4 channels to achieve tonal balance across the front stage.
Should I do this or should I leave my configuration as-is?
My amp runs 325 watts X 2 @ 4Ohms
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited August 2004
    IMHO I'd just leave it ...
    But if you are still using the stock metal jumper plates between the upper and lower terminals of the 15's then I'd replace them with some home made ones utilizing the same wire that you are running to the mains from you amp.
  • jrlouie
    jrlouie Posts: 462
    edited August 2004
    Thanks for your reply/opinion, I appreciate the feedback.
    Oy yeah, just as an FYI, I've actually in my current setup got the power-amp going to the Lsi15's bi-wired, so I'm currently not using the jumpers anyway.
  • Emlyn
    Emlyn Posts: 4,920
    edited August 2004
    I've found no benefit to biamping or biwiring on the LSi15s. Their unusual 3.5 way 4 ohm design seems to limit benefits of biamping. I have experienced speakers that do benefit from biamping, like the 8 ohm multiple subwoofer driver RTi150s and RTi12s, but I can't say the LSis do. I'd recommend using the best available high current, high damping factor, 200 to 400 watt into 4 ohm two channel amp with the LSi15s.
  • 2+2
    2+2 Posts: 546
    edited August 2004
    Intersting suggestion...when my goodies get here, I was planning to bi-amp the LSi15s using the separate amp, running the center with a channel from teh separate amp, and running the rears with the AVR. I would think that this would provide the most amount of power to the front/center....
    edit: re-read your post...I guess your separate amp is a 2 channel...so what I said would not apply...
    System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
    System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
    System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
    System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
