WTK Which Wall mount for FX500's
Crystalclear
Crystalclear Posts: 196
edited August 2004 in Speakers
Hi there,
I've got a set of Polk FX500's and need to mount them on a wall.What wall mount would you guys recommend for them.:)
Old School stuff
Sunfire Theater Grand Processor
Sunfire Cinema Grand 225x5 Amp
Monster AVS 2000 Signature
Polk RT800i's
Polk CS400i
Polk FX500's
(2) 2700 watt Sunfire Signature Subs
65' HDTV Mitsubishi Widescreen
  • wallstreet
    wallstreet Posts: 1,405
    edited August 2004
    omnimount
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2004
    How about the keyhole slot on the back side of the speaker.
  • scottvamp
    scottvamp Posts: 3,277
    edited August 2004
    It already has a key slot mount on the speakers themselves. I have made several custom brackets for the key slot application and they work great.
  • Crystalclear
    edited August 2004
    Well I thought of the slot but they need to be mounted on the side wall behind the couch near the roof.So they need to be slightly out from the wall pointing at a 45 degree angle.I hope that makes scense.I'll look for an omnimount bracket.:)
    Old School stuff
    Polk RT800i's
    Polk CS400i
    Polk FX500's
  • Frank Z
    edited August 2004
    I don't think you're going to like the sound with the speakers positioned the way you're describing.
  • scottvamp
    edited August 2004
    The design of the 500's they should be fine without the angle. I have built custom angling brackets in the past but commercial ones for that weight are probably pricey......
