BFD Channel seperation
jdhdiggs
Before I try this and start spinning my wheels, has anyone heard of or hooked up both channels of the BFD to the transmission line? If you connect the output of one to the input of the second, will that give you double the set points or are both channels locked at the same frequency for eq?
How many dB's would you be sacrificing?
There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
Post edited by jdhdiggs on
I am not sure what would happen if you put the output of one channel to the input of the other. But, the BFD has 12 filters per channel and each filter can be set to almost any frequency. Also each filter has a bandwidth of anything from 1/60th of an octave to 2 octaves. Check out this guide to using the BFD, it may answer some questions http://www.snapbug.ws/bfd.htm also, there are several BFD pros over at HTF.Graham
Yeah, I went through all the snapbug and links on house curves. I'm just trying to findout, before I do it, if it is worth the effort. The second channel would be just the ultra fine tuning. If no one has experience doing it, I might do it just for that reason alone.There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
I think it would work, but I dont think you will need it. I have a terrible room but I only use 4 filters for EQing and one for the house curve.Graham
