How to clean?
Curio
Curio Posts: 1
edited August 2004 in Speakers
My trusty old Polk RT5's have got a brownish dusty coating over the rubber on the drive units - what is this, and how can I clean it off? They have been in storage for about a year, but well covered up and packaged so I don't think it's just regular dust. Thanks.
  • venomclan
    venomclan Posts: 2,467
    edited August 2004
    Hi Curio,
    I had the same problem with my RT16's after a few years if use. Go to your local Office Depot and get a small bottle of Goo Gone. This is an adhesive remover and all purpose cleaner. Should cost about $3. Rub it in and it will make them shine like new. Goo Gone will not harm the drivers in any way. I use the stuff all over the place. A small bottle will go far. Good luck.
    Jeremy
  • dorokusai
    dorokusai Posts: 25,661
    edited August 2004
    I would suggest not to use Goo Gone, beings that it is basically turpentine/paint thinner. I love GG, but don't use it on my drivers. It is your call, it's your gear.
    The oxidation that is on the drivers is normal, and does not affect performance. It is what happens to rubber when it has an interaction with the atmosphere, beings that additives are in all rubber mixes to prevent rotting and cracking. The same thing happens to automobile tires. Consider it a good thing that it is present.
  • madmax
    madmax Posts: 12,434
    edited August 2004
    I tried Goo Gone on an SL2000 tweeter base once. Melted the black onto the towel and left permenant marks on the plastic. If I were to try anything it would be "Endust for Electronics". I used it on a surround for a PR once.
    madmax
    Vinyl, the final frontier...
