Stupid question for Lsi7's
avelanchefan
avelanchefan Posts: 2,401
edited August 2004 in Speakers
Ok I moved and have not hooked up my speakers until tomorrow. BUT, for the life of me I cannot rememer if I connect the wire to the top or bottom binding posts? I am doubting myself but I think I hook it up to the tops right?? (Bottoms are for use if you biwire)
Any help would be appreciated.
Sean
XboxLive--->avelanchefan
PSN---->Floppa
http://card.mygamercard.net/avelanchefan.png
    VR3 Posts: 29,762
    edited August 2004
    dont matter
  • madmax
    madmax Posts: 12,434
    edited August 2004
    It doesn't matter because that set of gold bracket strips hook the two together. I've heard it sounds better if you remove the gold strips and use wire between the connectors instead.
    madmax
    Vinyl, the final frontier...
  • Airplay355
    Airplay355 Posts: 4,298
    edited August 2004
    the top binding post goes to the tweeters and the bottom is to the woofers. the gold plate connects the two so you can plug wire into either set of posts as long as the gold plate is still there. when you bi-wire or bi-amp, you remove the gold plate because you have two runs of wire going to the speaker.
  • avelanchefan
    edited August 2004
    Alright thanks for the replies fellas. Just getting ready to set it all up (been without HT for 2 months now) So just getting anal about my setup.
    Sean
    PSN---->Floppa
  • dorokusai
    dorokusai Posts: 25,661
    edited August 2004
    That's just plain crazy, suprised you made it this far :)
