Psw 450
patriots
I bought a PSW 450 upgraded from the 350. The LOW Pass frequency range on the 350 was 60hz-160hz and the range on the PSW 450 is 60hz-120hz. Is this right ? The manual also shows a crossover frequency for the PSW 450 as 60hz-125hz as well.
Post edited by patriots on
Patriot-
Check the specs section on subs...
the 450...35-125 -3db
the 350...38-160 -3db
the 450 also has 50% more power.
it's an upgrade alright.
dig mine,
-luc -
Per Polk tech Support-they say the 350 is better matched to the RM 6600 due to the frequency response
