Just ordered my LSis. Need AVR+amp!
2+2 Posts: 546
edited August 2004 in Speakers
First, I wanted to thank all those who have offered advice in my other threads. As a resutl, I just placed an order for LSi15, LSiC and LSiFX with my dealer. I hope to have it in my home in about a week or two as they have to get black from Polk. I missed my budget for speakers by a large margin but that will just delay getting a large screen TV.
I now need something to drive them with. Upon advice of people here, I will be adding a dedicated amp. However, options in AVRs abound and I need advice/opinions. My inclination is to get a multichannel AVR to run the speakers at low volume during break-in period while I look for an amp, then use the AVR for a preamp/proc. The option of going AVR from Rotel or Adcam has been investigated but they dont have many features that I would want (headphone jack, tone controls, front jacks, etc. Besides, for that kind of price, it seems I can get an AVR and a full blown amp such as a midsize Rotel 2 channel or even 5 channel amps, not to mention used.
So which AVR and which amp combo works good with LSi? (Refurbs and used ok?)
I would prefer it to be able to drive my centers and surrounds so I can get a big 2 channel amp but if it can't, then it should be accordingly priced to allow me to get a 5 ch amp. I am budgeting about $1000 (+/- 15%) to the AVR + amp combo so please suggest accordingly.
AVRs:
HK: HK525 has been suggested and I will be going to Circuit City to take a look. I saw some HKs about 2 years ago and remember thinking that i did not like all the lights and the knobs (excuse me if that sounds lame). Maybe things have changed? Anyone know about the HK330? I heard these things can run high current.
Yamaha: I have some Yamaha components which are extremely reliable but I heard that pre amp features can be cumbersome to use.
Denon: Never used them but people here seem to like them...except that they can't drive 4 ohms...
Onkyo: My father runs the Grand Integra (before just "Integra"). I actually bought a 501 about 2 years ago. The power swich would not work so I returned it and didnt get anything....not a good impression. Didn't like the lack of knobs either for things like tone etc. Dont think they can run 4 ohms either but I will take a look at them at CC as well.
Am I missing anything?
As to amps. I have read good things about Crowns (pro-audio), Rotels and Outlaws. Is there any other reasonably priced amps I should consider that would sound good with an AVR?
Also, LSiFX has a strange shape...are there stands available?
Finally, what speaker wires/connects you guys use?
That's alot but I would appreciate insites. Thanks a bunch.....
System 1: Martin Logan Vantage, Rotel RC 1070, B&K Reference 200.2, Music Hall DAC 15.2, Yamaha 2300
System 2: LSi15 w/db840, Marantz SR8400, Rotel 1080, RM6800 (C&S), Sony X2020ES
System 3: LSi7, Yamaha SW215, Music Hall Maven, Music Hall MMF CD25 w/627opamps
System 4: RTi100, Harman Kardon AVR 230, Panasonic DVD
  • Frank Z
    Frank Z Posts: 5,860
    edited August 2004
    Outlaw 950 preamp and an Outlaw 7100 amp for $1598
  • sbrst58
    sbrst58 Posts: 13
    edited August 2004
    I recently read a private reveiw from a gent who purchased a Denon 3805 and a Outlaw 7100 to power LSIs, his opinoin was that combination sounded the best but settled on the 950/7100 combo to save $$
  • 2+2
    2+2 Posts: 546
    edited August 2004
    Outlaw...will have to check into them. Thx
  • Dr. Spec
    Dr. Spec Posts: 3,780
    edited August 2004
    NAD, Rotel, B&K, Outlaw.
    No need to get an AVR if you can get separates. Nothing wrong with using an AVR as a pre/pro, but you'll be buying your amps twice.
    I second Frank's recommendation on the Outlaw combo.
    If you insist on the AVR, then the Outlaw amps (either the 5 channel or a bunch of monoblocks) will do great. The M200 monoblocks are just awesome and mate very well with the LSi.
    I'm driving the Lsi with the M200 (300 continuous) and it doesn't break a sweat and sounds fabulous doing it.
    SVS
  • Frank Z
    edited August 2004
    D'oh!! 5 channels needed not 7! No sweat....755 instead of the 7100!!
  • 2+2
    2+2 Posts: 546
    edited August 2004
    Well, after a weekend of investigative work, I will likely get a Rotel 1075 amp (new or used if warranty still honored?). It's a 5 channel amp so my plan is to run my fronts and center with it. I have to learn about "bi-amping" as it has been suggested that some people do this for the fronts. I think this is suppose to provide more reserves since a separate power is provided to the woofer in the front speakers. I don't quite understand the details and how to do the connections. I also dont know what happens to the lower frequencies that are provided to the mids/tweeters and the high freqs. that are provided to the woofer....will have to investigate more.
    That also leaves me looking for an AVR to serve as pre/pro and run the rear LSiFXs.
    The final considerations are REFURBISHED:
    HK AVR-230 or 320 for $330 from HKaudio.
    Yamaha HTR-5660 for $230 shipped.
    If you know if one of these AVRs are more appropriate for pre/pro use and to drive rear LSiFX, please post. I would appreciate it.
    Daniel
