speaker placement....help!
audiobliss
Hey, guys. I need to know real quick where the surround speakers go. I'm hooking up my back speakers, and my receiver has a place for surround speakers and surround back speakers. The speakers I'm hooking up are going to go on the floor as close to the back wall as possible. Which terminals should I hook them up to?
Thanks!!
Thanks!!
In UseGeorge Grand wrote: »
Epson 8700UB
In Storage
[Home Audio]
Klipsch RF-35, RB-51ii
[Car Audio]
If you have five speakers, hook the surround speakers to surround outputs. The rear surround outputs are only if you have seven speakers. If you have to put the surround speakers on the floor, try aiming them at the ceiling if possible.Graham
I assume you are saying that you have 5 not 7 speakers and you are asking where the two that are not left, center and right get hooked up to ...
The answer is to the side or side surround terminals not the rear or rear surround terminals. -
lol; I actually currently have 4 speakers. they are going to be against the back wall on the floor. So, I should hook them to the surround terminals instead of the surround back?
Thanks!!!
Epson 8700UB
In Storage
[Home Audio]
[Car Audio]
