In-Wall Center Channel for RC85i?
What is the matching center channel for Polk In-Wall RC85i? I am trying to find a matching in-wall. Is it the TC265i?
Post edited by David B on
Yes, the TC 265i works great for it. Now realize taht the TC265 is 20 inches wide (studs are 16 inches apart) so if the wall is already built you will need to cut a studd or place it vertically. If you don't want to go through that I just suggest the LC65i one of those will handle the center channel just fine.
The LCi-C is really good too![ Home Theater ] 3 x LC265i for LCR and LC80fx rears plus Velodyne DD15 subwoofer using Denon 3808a processor with custom 5 channel amplifier and Oppo BDP-83 player.
