Guess I'll start from scratch vs upgrade Here's what I'm thinking
bakins
bakins Posts: 9
edited August 2004 in Speakers
I think I'll start from scratch on the speakers instead of mix matching. My room is 20 by 16. Here's what I'm thinking:
RTi8's front
CSi5 center or CSi3 Center?
FXi3's surround and rear
PSW300 sub (Existing)
Toshiba 57" Cinema Series (Existing)
Yamaha rx-v1400 (Existing)
Any advice? I'm not sure if I should get the RTi 8's or 10's or the CSI5 or 3?
  • bakins
    bakins Posts: 9
    edited August 2004
    I listened to them today actually. The 10's were definately fuller. I was concerned that it would be too much base. It seems like there should be a RTi9 with two midranges and one woofer :) I'll have to go back tomorrow and listen again for while longer.
  • jefft1314
    jefft1314 Posts: 169
    edited August 2004
    If you odn't plan on getting a new sub, get the 10's, it would be a wise choice I believe. They are defintiely fuller sounding/deeper.
