SVS Subwoofer Info
landry_p2000
landry_p2000 Posts: 1,313
edited August 2004 in Speakers
I keep on hearing about the SVS subs. Can anyone give me any info on where I can do research on buying one, or getting specs on the line of subs that SVS has to offer.
Main Set-up: 55" 120 hz Samsung LN55B650, Onkyo TX-SR806, Emotiva XPA-5, Emotiva XPA-2, PS3 Slim, Sony BDP-S560, Apple TV (160g), Panamax M5300-PM, Polk Audio CSi5, RTi10's, FXi3's, RTi4's, and SVS PB12 Plus
Bedroom: Panasonic 50" S2 Plasma and Panasonic BD65 blu-ray player, Onkyo TX-SR707, Emotiva XPA-3, Emotiva UPA-2, KEF IQ7's, IQc, IQ8Ds, and SVS PB10-ISD
  • Willow
    Willow Posts: 11,370
    edited August 2004
  • landry_p2000
    edited August 2004
    Thanks Willow. I put in www.svs.com and some bullcrap came up.
  • landry_p2000
    edited August 2004
    Which model do you guys recommend?
  • tryrrthg
    tryrrthg Posts: 1,896
    edited August 2004
    depends on how much you want to spend. how big your room is, how loud you listen, etc...
  • faster100
    faster100 Posts: 6,124
    edited August 2004
    yeah what he said.. some best price subs are the cyclinder subs, like the pci 20-39 // some best bang for your buck sub is the Pb2-isd in a box design.. But this will all depend on your budget and room size..
    I have the Pb2-isd and love it.. started with the pb1-isd and it was very nice as well... Good luck
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    LSIfx surround backs
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Rotel 1080 stereo amp
    Polk sda 2B
    kenwood grunt Tuner
    realistic lab 450 TT
    Signal cable IC
  • landry_p2000
    edited August 2004
    I am trying to stay around $700 bucks if I can. This is going to be a "gift to me" deal. My den is about 16'x21' give or take a few feet.
  • Willow
    edited August 2004
    click on my link you must enter the whole thing not just SVS.com
  • tryrrthg
    edited August 2004
    If that's your limit go with PC+ cylinder subs. Either the 25-31PC+ (most SPL, less extension) or 20-39PC+ (best of both worlds, a little loss of SPL from the 25-31, but more extension).
  • tryrrthg
    edited August 2004
    oops, just realized the PC+ starts at $775. But I'd still reccomend them if you're willing to spend $700 spend a little more for the better sub.
  • AsSiMiLaTeD
    AsSiMiLaTeD Posts: 11,728
    edited August 2004
    I have the PCi16-46 and love it. The smaller subs in that line will go a bit louder, but this thing trolls deeper than sin...
    Are you looking more for music of HT? If HT, I'd definitely reccomend that sub, for music you may want to look at one of the smaller subs in that line. You'll get more price/performance ratio our of a cylinder sub, if you can go that route...
