Denon 3805 & Lsi25, Lsi15, Lsi9. ARE THEY COMPATIBLE?
Tweakerhead
Tweakerhead Posts: 4
edited August 2004 in Speakers
I recently emailed Denon's Tech Dept, to ask about the capability of the 3805 & 4ohm speakers in general, particularly the Lsi25,15, & Lsi9. Here is the email.
Hello,
Can the Denon avr-3805 comfortably power a 5.1 Speaker system that consists of only 4ohm speakers. I have heard different opinions & was wondering what your opinion was. Thank You, Eric
DENON's response
Hi,
We do not recommend using 4 ohm speakers with any of our units. It may cause the unit to overheat and shut down at higher volumes. Please use 6 ohm or higher.
I need some feedback from people who own a denon 3805 & some Lsi polks. I have heard that the Lsi Polks actually run closer to 6 ohms in "real world" use. I get the feeling denon responded in that way due to warranty issues. An old word called Liability. I want to get a denon 3805 with an lsi25,15,9...not sure yet...lsic,lsifx,lsiw... Everyones input is welcome especially people who actually own the equipment in Question. Thank You, Eric
  • Tweakerhead
    edited August 2004
    Do you mind if I ask you how you came to that conclusion. What receiver do you reccommend? $1000 or less.
  • jdhdiggs
    jdhdiggs Posts: 4,305
    edited August 2004
    LSi's are also some of the "higher impedence" 4ohm speakers. Looking at the impedence graphs, the speakers should be labelled as 6 ohm, not four. As far as the 15 and 25, since those have powered woofs, they should be very easy to drive. I'll send you a link with the impedence curve of the 9's when I find it again.
    Charts for LSi9
    There is no genuine justice in any scheme of feeding and coddling the loafer whose only ponderable energies are devoted wholly to reproduction. Nine-tenths of the rights he bellows for are really privileges and he does nothing to deserve them. We not only acquired a vast population of morons, we have inculcated all morons, old or young, with the doctrine that the decent and industrious people of the country are bound to support them for all time.-Menkin
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited August 2004
  • jdhdiggs
    edited August 2004
    Originally posted by PolkWannabie
    The 25's are powered ... The 15's are not ...
    Whoops, my bad...
  • amulford
    amulford Posts: 5,020
    edited August 2004
    This was discussed not long ago. Please check this out
  • Sami
    Sami Posts: 4,634
    edited August 2004
    If you want a new receiver with warranty, I would get H/K AVR7200. For a receiver it has good current, 70A. I don't know if I would want to run the 15's but 7's and 9's should have no problem mating with it. You should consider used amps.
