F/S B&K AV6000 MKII 6x125watts amp AND PSW202 subwoofers
francis1967
For sale is an excellent condition (8/10 using Audiogon scale) B&K six channel power amp, the AV6000 Series II, release 1999, this unit is 2 1/2 yrs old, I am second owner. A couple of scratches underneath (not visible, of course), faceplate mint, top has three hairline scratches and one side has a scratch, say 4 hairs thick, 1/2 inch long. Sonically and technically perfect working order. Never clipped, don't listen to anything louder than -20db. User manual is still unread.
Six channels is very useful: if you want to bi-amp those main speakers in a 5.1 setup (this was my setup..awesome); if you need that extra channel to drive a passive sub; if you want to move into 6.1 format and need a six channel for the rear center; or just migrate to separates inexpensively with a quality component.
I have used this with some LSi-9s and LSi-7s and it drives these speaks beautifully with its 6x 185watts into 4ohms. Into 8ohms they are 125 watts @ 1 kHz.
B&K AV6000 MKII user manual
Retail $1699, selling it for $600 . That's a Franklin for each 125watts/channel of B&K smooth, dynamic music/movie sound. Have seen similar amp on Ebay for $750-$800.
Is it a good deal? Should hope so as someone just listed its older cousin the AV6000 on Audiogon for $650 and its only 105watts per channel compared to 6x125w on my newer MKII. Fyi link to older av6000
Shipping ground from CA 92120 is extra. Pick-ups ok. Auditions ok.
Oh, I have also two PSW202 subs for sale too. I bought these here from Brett earlier for $150 and will sell for same price, $150 for both. Still "as new" condition and sparingly used. Don't have the boxes so pick-up is preferable. Sold separately I am asking $99/each.
Any takers?
Michael.
NOTE. I HAVE PHOTOS OF AMP...filesize is too big to post here, so ask and ye will receive...via email, that is...
Any takers?
Michael.
I might be interested. How much would it cost to ship to MD 21713? How heavy is the amp?
I expect the shipping weight is about 50 lbs incl packaging.
Here are the specs on the amp:
Power rating: 8 ohms 125 watts @ 1 kHz
4 ohms 185 watts @ 1 kHz
Frequency response 5 Hz - 45 kHz
Input sensitivity 1.0 Volts
THD (S+N) 0.09 % @ 1 kHz
Input impedance 33.2 k ohms
Damping factor 150
Current (peak to peak) 30 Amps
Slew rate 14 V / )sec
Dynamic headroom 1.4 dB
S/N (A-weighted) 95 dB
Voltage gain 28
Line voltage 120/220/240 VAC switchable
Dimensions (O.A.) 17"(w) X 16"(d) X 5.75"(h)
Weight 43 lb
Power consumption 1412 watts max
14.5 Amps max current draw
130 watts @ no input
Replacement fuses Line -12 Amp/250 Volt Slow Blow
Rails - 4 Amp/250 Volt Slow Blow -
Shell, you've been PM'ed.
Francis, Sorry I will have to pass on the amp.
