2 amps, one set of speakers...
Early B.
A friend of mine is reconfiguring his HT/audio room. He has a separate HT system and a 2-channel system. Once he changes stuff around, he'll be using his front HT speakers for 2-channel playback. I wanted to make sure I am giving him the right advice.
I came up with two options:
1. buy a Niles Audio DPS-1 amp selector
2. Get two pair of RCA cables and use two y-adapters at the amp end. Plug one set into the LR pre-outs of the receiver and the other into his pre-amp. He'll need to split the signal between systems with his subwoofer as well.
Any problems with hooking it up this way?
Thanks.
Thanks.
HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes."
