Front speaker recommendations?
pwglick
I currently have a setup which consists of the following speakers:
Fronts: RT16
Center: CS350
Surrounds: LS/fx
Sub: PSW650
I have an entertainment center and I'd like to replace the RT16 with a bookshelf size speaker which will sit inside the entertainment cabinet. The RT55i would be perfect, except it's about 1 inch too tall.
Does anyone have any other recommendations for a set of front speakers?
The receiver is a Sony-STRDA777ES, which drives around 100 watts /channel.
Thanks,
Phil
Fronts: RT16
Center: CS350
Surrounds: LS/fx
Sub: PSW650
Thanks,
Phil
Post edited by RyanC_Masimo on
LSi9's! They're smaller than the RT55i's and sound oh so much better.
Aaron -
the LSi9 would be it, sounds like your only other option would be rt35i's to fit in the cabinet, but i think you would be losing alot of sound coming from rt16's...
take it form aaron, he's heard the LSi's... -
I dunno if that receiver is the best match for the LSi9, power wise though...
TroyI plan for the future. - F1Nut -
Aaron -
aaron jut wants to see another rec. flaming...:D
is there anyway you can modify your cabinet to make that extra inch you need for the 55i's? -
The side sections of the cabinet (speaker area) are a fixed width and height (around 20"). Depth isn't a problem.
I was wrong about the rating of the receiver. It's rated 120 watts /channel (8 ohm). The receiver is also rated at 4ohms (I don't remember the exact wattage).
Would it still require a separate amp, given the receiver's rating?
Thanks,
Phil
