Do it on the floor
Early B.
Early B. Posts: 7,900
Anyone ever do any critical listening while sitting on the floor? Try it if you haven't. IMO, it puts you inside the music. Of course, you can feel the bass reverberating off the floor. Be careful though, while listening to female vocals. You may leave a stain on the carpet.
"God grooves with tubes."
    F1nut Posts: 52,007
    edited August 2004
    :D
  • I-SIG
    I-SIG Posts: 2,243
    edited August 2004
    Listening while sitting on the floor doesn't do anything for me and my 1C's.
    Wes
    Link: http://polkarmy.com/forums
    Sony 75" Bravia 4K | Polk Audio SDA-SRS's (w/RDO's & Vampire Posts) + SVS PC+ 25-31 | AudioQuest Granite (mids) + BWA Silver (highs) | Cary Audio CAD-200 | Signal Cable Silver Resolution XLR's | Rotel Michi P5 | Signal Cable Silver Resolution XLR's | Cambridge Audio azur 840C--Wadia 170i + iPod jammed w/ lossless audio--Oppo 970 | Pure|AV PF31d
  • TroyD
    TroyD Posts: 13,124
    edited August 2004
    Me neither. Just makes my **** sore.
    I may try Dan's HASSAN CHOP! position though.
    BDT
  • Airplay355
    Airplay355 Posts: 4,298
    edited August 2004
    try listening backwards, with your mains behind you. if your surrounds are setup right, you wont even know they are there.
  • Strong Bad
    Strong Bad Posts: 4,278
    edited August 2004
    After about 2 minutes of sitting indian style on the floor, I can't concentrate on the music because my hips, knees and feet go numb. Then it's a struggle just to try and stand up.
    Such a **** getting older! I'll sit in a comfy chair thank you!
    Strong Bad
    No excuses!
  • nadams
    nadams Posts: 5,877
    edited August 2004
    My impression was that if you have your speakers set up ideally, your sweet spot should be in your favorite chair....
    My speakers sound better when I sit on the floor (or even stand in odd places in my room) because I don't have them set up properly. they don't have enough space, and I'm missing the stands that they are supposed to sit on. I'm still sitting on my chair, tho.... my floor is covered in computer parts and magazines... no room to sit!
    nadams
    Ludicrous gibs!
  • Early B.
    edited August 2004
    I'd like to set my speakers up higher, but there's the aesthetics factor to consider. Won't look right, so I gotta make concessions. Polk recommends 28 - 34 inch stands for Lsi7's. Mine are 24".
