dual csi3s or get a csi5 ?
Codey
Codey Posts: 188
edited August 2004 in Speakers
Can anyone offer their opinion on which setup would sound better ?
Outlaw 950
GFA-555
GFA-545
GFA-2535
RTi8s
CSi5
FXi3s
214L Vented Tempest
250w BASH amp
Toshiba HDA1
Toshiba 44" DLP
NAD 533 Turntable
Tripplite HT3100
Xbox 360
  • jefft1314
    jefft1314 Posts: 169
    edited August 2004
    Csi-5 unless you are using a front projecter and can put a csi-3 above and below the screen.
  • Codey
    Codey Posts: 188
    edited August 2004
    I don't have a front projector, I was just thinking of putting two csi3s side by side under the T.V. because they would fit in my entertainement unit better than a csi5.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • marcpam
    marcpam Posts: 228
    edited August 2004
    what would you power them with?
  • jefft1314
    edited August 2004
    Sound quality will be better on the CSI-5 alone I would imagine. Otherwise you'd get an effect known as comb filtering. I hear it's not very pleasant. I'm surprised more people haven't chimed in here. I'd also post the question over at avsforum.com, they'd be able to do a better job of explaining why the csi5 will sound better than i can. Or you can just take my word on it, or I suppose you could try it out for yourself and see what works best. I'm guessing you already have one csi3?
  • Codey
    Codey Posts: 188
    edited August 2004
    I was thinking of using an adcom 545 or something like that to power them. I guess I could always save the csi3 I have for 6.1 in the near future , and modify my entertainement centre to accomodate the csi5. I was just looking for an easier way out.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • scottvamp
    scottvamp Posts: 3,277
    edited August 2004
    The question is - who big is your TV? A 36" or under does not benifit from mutilple centers.....
  • Willow
    Willow Posts: 11,371
    edited August 2004
    I dont see how 2 fronts will seem better with a big screen unless you have a major projection system or at the theaters. Are you happy with your csi3 ? if so keep it what do you think, or how do you think upgrading will benefit you ??
  • Larry Chanin
    Larry Chanin Posts: 601
    edited August 2004
    Hi Jeff,
    You might be interested in an other recent Club Polk thread on this subject.
    Dual Centers for Front Projection?
    In that thread I mention that I already posted the question at AV Sciences Home Theater Builder's forum.
    Stacking Dual Center Channel Speakers?
    Some professionals may be concerned about comb filtering, but I think the concern may be over stated. I'm not a 2-channel enthusiast, but I would think that if comb filtering were a problem, then everytime an enthusiast had friends over to to listen to stereo the people sitting off-axis would be confronted with comb filtering, right? But somehow, despite the fact than many 2-channel enthusiasts are audiophiles, we never heard about that problem.
    You get comb filtering when there is a delay in two identical signals so that, depending on the difference in delay, the signals constructively or destructively intefer with one an other. Therefore anyone sitting off-axis listening to 2-channel stereo where the sonic image is intended to be centered, would theoretically be subjected to comb filtering because there will be a delay between the right and left speaker due to the difference in distance.
    Now, let's discuss why stacked centers present less of a problem, (if there's a problem in the first place.) When you stack centers you have the option of arranging the center channel speakers so that they are equidistant from the primary listening area. If the listeners are the same distance from each speaker then comb filtering can't occur. Unlike the stereo example, in this case even listeners seated off-axis will still be equidistant from both speakers so comb filtering should not be an issue.
    Larry
  • Codey
    Codey Posts: 188
    edited August 2004
    Thank you for your help guys. I think I'm just going to suck it up and make a csi5 fit and use the csi3 for a rear center.
    Outlaw 950
    GFA-555
    GFA-545
    GFA-2535
    RTi8s
    CSi5
    FXi3s
    214L Vented Tempest
    250w BASH amp
    Toshiba HDA1
    Toshiba 44" DLP
    NAD 533 Turntable
    Tripplite HT3100
    Xbox 360
  • jefft1314
    edited August 2004
    Thanks Larry, I was aware that stacking the centers wouldn't be an issue but I was pretty sure having them side by side wouldn't work out too well, as this would present problems with distance. And as this was the original posters intent, I figured a single csi 5 woudl be a better solution. If you read up in the thread you'll see that i said that actually having one underneath, and one on top of the screen should work out well, but I didn't think placing them side by side would be a great idea. Thanks for the good explanation of comb filtering though, that clears things up for me.
  • Larry Chanin
    edited August 2004
    Hi Jeff,
    Sorry I missed that previous posting.
    I'm inclined to agree with you that, in theory, horizontally placed centers should present more comb filtering problems than vertically placed centers. In addition, from a personal preference point of view, I would rather have a focused center sonic image to anchor dialog versus a diffuse wide image.
    Nevertheless, there are several members of this forum who have reported excellent results with horizontal configurations.
    Larry
  • wallstreet
    wallstreet Posts: 1,405
    edited August 2004
    You can get all the csi3's you want and you'll end up with very loud db's within the frequency range of the speaker. The csi5 has a larger frequency range which can never be reproduced by the csi3. If at all possible, go with the 5.
  • Toxis
    Toxis Posts: 5,116
    edited August 2004
    CSi5 > dual 3's. No matter how many centers you add, it will not enhance the midbass from a speaker. The 3 sounds good but compared to the 5, it falls flat on it's face. No midbass what-so-ever. It lacks the depth you want to match up with larger towers. Go the 5 and be happy...
  • Willow
    edited August 2004
    the 5 is really that much better than the 3 ?? shoot I'll have to keep my eyes opened !!
    Now will the 5 be to much for my rti4's as mains ??
  • Early B.
    Early B. Posts: 7,900
    edited August 2004
    No.
    "God grooves with tubes."
  • Toxis
    Toxis Posts: 5,116
    edited August 2004
    IMO, yes! I sell Polk and have done hundreds upon hundreds of listening sessions with Polk (seeing it's my favorite speaker line we carry). I think the 5 completely dominates the mains if you're using bookshelves (4's or 6's) but if you're running towers, the 5 is a necessity as the 3 will not keep up. Again, just my opinion. Yes I know you can adjust the volume of the channels to match the levels but I'm talking about dynamics...
  • PolkWannabie
    PolkWannabie Posts: 2,763
    edited August 2004
    That's why receivers and preamps have channel level adjustments ... for calibration ...
  • TheReaper
    TheReaper Posts: 636
    edited August 2004
    I think this is good advice. I tried a CSi5 with my R50s, and I took it back. Things just didn't sound right with more bass coming from the center, then from the mains.
    Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70
