CS350 tweeter upgrade
Currently I am using this center channel with my 1.2TLs and have wondered if I matched the tweeter in the center channel to the 1.2TLs if it would help. What I don't know is if it only requires installing the SL3000, or if it's more involved than that (crossover, etc). Any help would be appreciated.
Driver carries only 20 dollars in ammunition
Pedestrians have the right of way, unless they are in the way
Bump! Someone has to know the answer to this.
Thanks! Driver carries only 20 dollars in ammunition
Pedestrians have the right of way, unless they are in the way -
Wow, I can't believe there is no one here that can help. Well I guess I will go it alone and see how replacing the tweeter works.Driver carries only 20 dollars in ammunition
