F/S PSW-350 10" sub
qman
qman Posts: 7
edited August 2004 in Flea Market
Polk PSW 350. 7/10 - a few scratches here and there nothing noticeable until up close none thru veneer. $125. UPS ground shipping $25 or local pickup/delivery in Houston, TX. I'm upgrading. thequinns at mail dot com
The PSW350 features:
10-inch direct radiating subwoofer driver for deep bass
Dual flared ports for low distortion
High current power amplifier
Magnetically shielded for safe placement near your TV
Auto on/off circuit that automatically turns your subwoofer on when it senses a program signal. When no signal is present, the amplifier turns off within 15 minutes
Unfiltered LFE input for use with low pass filtered subwoofer output jacks
Adjustable lowpass crossover, phase switch and volume control allows perfect blending with any main speaker.
Driver Complement
Subwoofer 1 - 10" Diameter (25.40cm)
Polymer composite driver
Electrical
Overall Frequency Response 25Hz - 180Hz
Lower -3dB Limit 38Hz
Upper -3dB Limit 160Hz
Crossover adjustable LPF 60Hz - 160Hz
Inputs speaker, line, LFE (unfiltered)
Outputs speaker level
Dimensions
Cabinet Size 15" H x 13-1/2" W x 18-1/2" D
(38.10cm H x 34.29cm W x 46.99cm D)
Radiation Pattern direct
Enclosure Type Vented, dual flared ports
Power Output 100 watts Continuous Average Output
Dynamic Power Output 200 watts
Post edited by qman on
