sub woofer
comet
when mesuring the sound of the sub is it -3db higher or lower then what the meter reads?
Post edited by comet on
It depends on the frequency you are measuring. Here is a list of the correction factors. http://www.hometheaterforum.com/htforum/showthread.php?s=&threadid=26728Graham
sorry i meat when playing the test tones from the reciever
It depends on the frequency the receiver is playing, but adding 3 dB should be fine.Graham
I am sure this is what you meant Gatemplin, but to have an even calibration, your sub should be set 2-3 dB below what you set your other speakers at. That being said, many calibrate their subs higher than that for movies.
Greg -
Right Greg, I meant add 2-3 dB to the reading on the sub tone. Thanks for clarifying.Graham
