Snap Crackle Pop . GFA 545
Pauly
So the new (to me) amp is giving me hassles IMO. When i turn on i get a pop from the speakers...not a loud one, but enough to hear. also when i change the channels (FM) i get a pop as well...Anyone chime in on this one? The amp seems to play fine, no distortion lights on or anything like that..Somthing going bad in the adcom?
Paul
Paul
Life without music would♭
Post edited by Pauly on
The amp does *pop* when u turn it on... and when you turn it off, the speakers will make noise for a bit, for like a second....
As for the noise in changing, that is probally the preamp...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
Well it never did it when i had cliffs tube or his rotel hooked up on it?? Has to be something to do with he Adcom.
Anyone else?Life without music would♭ -
Do you have another stereo handy you can hook the amp up to, for testing? Is there some kind of gain control that is too high?
I have the Oink 801 but no way i am unhooking that thing...that would be an all day affair. Was thinking of hooking up another pair of speakers to see if it is the M 10s but i doubt it...It just started when i hooked up the adcom as when i use the HK by itself it doesnt do it. It has to be the amp, Everything is hooked up right.Life without music would♭
Maybe a grounding issue. Have you taken the cover off to see if there is anything that looks obviously wrong?
You could just run a single rca from one on the Oinks preamp outs (set to All channel St) to a single input on the adcom, then check each input on the adcom for the problem.
ok i just noticed when i change from cd to tuner or visa/versa i get the same effect. When its turned up 70-80db and i switch, you cant hear it, but when levels are low you can hear it...WTF this is pissing me offLife without music would♭
How is all the stuff plugged in? Sharing a power strip etc?
drag the Rti's of your choice in there and see if its somehow the M10's... If it didnt do it on the rotel, or the Dynakit i highly doubt its the pre-amp. Its plugged straight to the wall i believe... It all started when you got the adcom, so i suspect its simply the adcom amp.. Had we not used it on 2 other amps with no problem i would think otherwise, I know you dont want to think its the amp... But i think it is unfortunatly..MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC -
yeah i swapped from wall to strip then back to wall....gotta be the amp. everything is grounded fine wires tight and correct as he rca's.......bummer maybe i'll send her back
PaulyLife without music would♭ -
well ya had a amp for alittle bit anyways,, so how do the 10's sound on it ? assuming it works besides the pops,.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
drives them pretty good. sounds alot better than just the HK driving them. More bright , but all around not bad for 125.00. Gonna wait to get this pre from Mike to see before i cause a scene with the sellerLife without music would♭
So the pre on the way? you could try that... I noticed the bios voltage higher when i ran the tube on your HK, then when i took it home was back to normal... Im thinking it has a high output voltgage and its driveing the amp harder or something. Try the preamp and see what it does.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
You know it has that "loudness" button on the HK that might have something to do with it...I'll be sending the Money this week for him to pick her upLife without music would♭
Originally posted by spasticpitbull
You know it has that "loudness" button on the HK that might have something to do with it..."
Interesting you say that. Loudness boosts the bass and treble at low volumes but not at higher volumes, and you said there wasn't a problem at higher volumes, right? May or may not be related I guess. Have you tried Adcom support, they might know right away "Sounds like part 'b' went bad, we can replace that for 'x' amount."
good luck -
i think when you have your receiver turned on.. then the Adcom comes on.. it will make a popping sound.. or it's vice versa.. i can't remember which is the one.PolkFest 2012, who's going>?
good luck
So i just mentioned about the Loudness button that may have caused this on his tube. This has nothign to do with the Popping.
What i ment was that you just cant hear the Pop at loud levels only at low levels...meaning the Music carrys over the POpping so u cant hear it.
Make sense?Life without music would♭ -
What's your power up sequence?
Amp on LAST, off FIRST? There is nothing wrong with your amp, imo. Have you tried it with a different preamp?
A thump on startup is not uncommon, but if it's thumping between sources, it's amplifying something from the control amplifier (pre).
Cheers,
Was 1st, 1st so i can drain the power in the caps when i was done. Will turn on last now. So the thumping between sources, will it fry the amp?Life without music would♭
It is your speakers that will take the brunt of the 'thump'.
Anytime you are dealing separates, always amp on last, off first.
Cheers,
He's saying, its "most likely" the pre-amp is where the noise is, and the adcom is amplifying the noise. I would wait for the adcom pre you have coming or try it on the Onkyo see if it go's away.MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Polk sda 2B
kenwood grunt Tuner
Signal cable IC -
ok well its not LOUD, but is annoying...will wait for this other pre and go from there...
Thanks Guys
U could always send it to me if u dont like it
Nah, JK - I hope you find out what is wrong....but it sounds normal to me, other than the pop during changing sources....- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit. -
I have a GFA-545, had it for 10 years now. Not one single problem, ever! The thumping is normal and is not harmful in any way, shape or form. You should however turn the amp off first to drain the caps and then turn off other components. Go to Adcom's web site for an explanation of why Adcom amps do this. It is explained in the owners manual also. If you didn't get one you can d/l it from the website.
As far as the other problem it sounds like the pre/control amp switching. Why I don't know, but most likely it's not the amp that is causing the problem
Hope this helps
BrockADCOM GFA-545 AMP
NAK CA-5 PRE-AMP
NAK MB2S CD
ADCOM GDA-700 DAC
POLK RTA-11T
MONSTER CABLE INTERCONNECTS
2 CHANNEL AND STILL LOVING IT!!! -
Here is a couple of pics of the adcom pre I am shipping to spaz, one of the pre itself and one of it in action."Its worked so far but we're not out yet."
"Hey big man let me hold a dollar" -
Dammit."Its worked so far but we're not out yet."
Here is the pre in action."Its worked so far but we're not out yet."
And a rear view."Its worked so far but we're not out yet."
Good deal..looks great. Thanks for help. tried to PM you but you inbox was full. I'll let you know when i get it
PaulLife without music would♭ -
Inbox is clean."Its worked so far but we're not out yet."
