Tv Hook Up
Phantom 1
I would like to know how to get my TV to work through my Yamaha Receiver it works fine with my DVD and the stereo works but I can"t get the TV to work through the speakers?
Post edited by Phantom 1 on
How is the TV signal supplied ? via dish ? cable ? antenna ?
If by antenna does your TV have audio out jacks ? -
I have cable
If your cable box has a digital output (Toslink) connect it to your receiver and make sure the the input is turned on via your OSD. Depending on your receiver, you may need to select which digital input to use for the TV.
Thanks. I was about to post the same question. The HK receiver manuals ain't the greatest.HT/2-channel Rig: Sony 50 LCD TV; Toshiba HD-A2 DVD player; Emotiva LMC-1 pre/pro; Rogue Audio M-120 monoblocks (modded); Placette RVC; Emotiva LPA-1 amp; Bada HD-22 tube CDP (modded); VMPS Tower II SE (fronts); DIY Clearwave Dynamic 4CC (center); Wharfedale Opus Tri-Surrounds (rear); and VMPS 215 sub
"God grooves with tubes." -
I do not have a cable box its just a cable and it is hooked up to a splitter then to the tv and dvd.
Does your TV have Audio-Out jacks?
Give us as much info as possible, model of tv, receiver, etc. -
If you don't have audio out jacks on your TV:
How about a VCR, if you have one, they frequently have audio out jacks.Win7 Media Center -> Onkyo TXSR702 -> Polk Rti70 -
First I want to thank all who are trying to help me,here is the info I have a 29" RCA TV Yamaha recv HTR 5600 Polk Audio spekers 5.1 From Cable in the wall to a splitter ,from splitter to TV and From splitter to to Recv for my Fm Stations - Audio r n l video from recv to Dvd -Video input 1 from Tv to Video monitor out on Recv-sub oofer cable out on Recv to Subwoofer -CD aidio r n l to Cd player line out R n L ,oh yea Cd player Technics slpd 607. hope this helps thanks again.
Does your TV have audio out jacks ?
Yes it does
Ok ... well then you should be able to run RCA's from the output jacks of the TV to input jacks on your receiver and then get sound through your sound system.
ok I will give that a try thanks
