wired in series
Systems
Systems Posts: 14,872
edited July 2004 in Car Subwoofer Talk
how would i wire 2 single voice coil subs in series??my amp puts out 200x2 at 4ohh and 300x2at 2 ohm.the guy on crutchfield said i would have to wire the subs in a series to get 150 watts to each sub so i dont blow them.
Testing
Testing
Testing
  • Jstas
    Jstas Posts: 14,993
    edited July 2004
    Here you go, this link should help you out. It's a SoundDomain online tool for wiring. You can select configurations and have it give you a wiring diagram.
    http://www.cardomain.com/shop/wooferwizard.pl?num_of_subs=1&impedance_of_subs=dual%204%20ohms
    Expert Moron Extraordinaire
  • MacLeod
    MacLeod Posts: 14,358
    edited July 2004
    If Im understanding you correctly, your amp puts out 300x1 at 4 ohms bridged mono. If this is right then the only way you can run 2 subs and get a 4 ohm load is if they are both 8 ohm subs.
    Im currently running a pair of 8 ohm JL Audio 8s and I have them wired in series running off my Crossfire 2 channel and Im running a 4 ohm load.
    If your subs are 4 ohm and you wire them in series it will present an 8 ohm load to your amp and youll only be getting 150x1 which would be 75x2.
    What kind of subs and amp are you running?
  • Systems
    edited July 2004
    no its 600x1 at 4 ohm bridged..
    Testing
    Testing
    Testing
