good CHEAP termnial cups
Airplay355
does anyone know where i can find good, cheap, terminal cups? they don't need to be anythign special but they do need to be 5 way binding posts. they are going to be used on a sub so biwiring isnt necessary.
Ratshack maybe?
Both of the vendors suggested above have something that'll likely satisfy you. Here's an example, from PartsExpress:
http://www.partsexpress.com/pe/showdetl.cfm?&DID=7&Partnumber=260-309 -
I'd suggest getting the partsexpress catalog, it's free and has a ton of supplies. I heard the Focals are cheap.
Why the binding posts on a sub instead of an LFE input?comment comment comment comment. bitchy.
He is building a car subwoofer...- Not Tom ::::::: Any system can play Diana Krall. Only the best can play Limp Bizkit.
