sdaic polyswitch
transamz
transamz Posts: 15
edited July 2004 in Speakers
hi all i changed the polyswitches in my sdaic speakers but even at moderate listening level my tweeters in the left speakers shuts down .i am feeding them with a amp rated at 260 watts per channel ,what gives need advice
    F1nut Posts: 52,406
    edited July 2004
    Hmmmm......swap the left tweets with the right tweets and report back. Also, check the interconnects and speaker cables for any shorts or bad wires.
  • transamz
    transamz Posts: 15
    edited July 2004
    :):) Hey fi switched top tweeters only on each speaker and backed off the treble,all systems seem to be go thanks for the suggestion. I think i had to much treble going to the tweets thats why they were shutting down now I am glad the poly switch was there or I probly would have fried the tweets ,by the way where do you set your bass and treble settings.
  • dorokusai
    dorokusai Posts: 25,661
    edited July 2004
    Report back? Who are you Colonel Polk? sheesh :D
  • transamz
    transamz Posts: 15
    edited July 2004
    Dorokusai i dont think he meant it in a bad way by saying report back and if he did i did not take it that way i am just looking for advice not flame wars maybe this gentlemen is a young guy and will learn in time what words to use and when .do you have any suggestions on yhe problem my left tweets shuts down when asked to isolate a certain instrument.thanks and peace to all in the polk family
  • nadams
    nadams Posts: 5,877
    edited July 2004
    transamz- the comment from doro was meant in jest. We're all friends here :-) (at least, mostly...)
    Anyway. I seem to remember someone else having this identical problem a while back. Let me search around and see what I can find.
    Ludicrous gibs!
    F1nut Posts: 52,406
    edited July 2004
    "...this gentlemen is a young guy..."
    Yeah, eat my shorts Doro you old ****. :D
    Transamz, actually he's younger than me. Anyway, he was joking and besides that I know where he lives. IMO, one should keep the treble and bass flat, in fact if you have a direct (bypass) switch use it for even cleaner sound.
  • dorokusai
    edited July 2004
    F1 happens to be one of my best friends, and I'm fully aware of what he was trying to do. Good luck.
