Set-up Questions
bkfk
I HAVE THREE QUESTIONS;MY SET-UP INCLUDES RT55'S,CS400 AND POWERED BIC SUB CONNECTED TO A DENON 3802.WOULD THE RT55'S BE CONSIDERED LARGE OR SMALL SPEAKERS?WHAT SHOULD CROSSOVER BE SET AT 80HZ,100HZ'..?ALSO I HAVE RM3000 WITH PASSIVE SUB IN BACK.WOULD IT BE BETTER TO WIRE THESE TO ALL MEET AT THE RECEIVER OR CONNECT SPEAKERS TO SUB AND THEN SUB TO RECEIVER?
Post edited by bkfk on
I think the 55i's should be set to large with 80Hz as your crossover point. Try the 400i at both small and large to find out which sounds the best to you. I've tried it both ways and prefer that it remain small.
Not sure what to recommend regarding your other questions. -
I have the RM3000 and have wired them several ways. Wiring them all back to the receiver sems to work well in my current setup.
I've also "biwired" in previous setups. Wire the Sats to speaker A and the Sub to speaker B. I was previously running an old Sony Reciever from the 70's and this biwiring sounded great. On my current setup, biwirng did not sound as tight as keeping them on the same speaker channel.
Anyone else have advice on biwiring?
