Enclosure Volume Calculation
crx_si_1990
I have a pair of MM124s and have a quick question about the recommended enclosure volume. I know it is .88 cubic ft, but the issue is that polk did not include the basket volume of the speaker so that it can be accounted for, nor did they write in the manual whether the .88 cubic ft was accounting for the volume of air occupied by the woofer itself.
In short: Does anyone know the volume of the motor structure of the MM124?
I'm guessing that it is not accounted for because .88 cubic ft is a fairly small enclosure. So I need to add the basket volume to the .88 to get the enclosure volume I need in the empty boxes.
Thanks,
Nick
Thanks,
Nick
Post edited by crx_si_1990 on
your box needs to be .88ft without the driver inside it...if thats what youre asking
-CodyMusic is like candy, you have to get rid of the rappers to enjoy it
