rm6000
fab
i got rm6000 surround what is the best way to hook up my sub and front speakers parralel wire hook up or thru my sub amp .
do i get any distortion if a use the parralel wire hook up way ?
do i loose watts if ago thru my sub amp ?
considering my receiver i a 100w per ch and the sub amp is only 50w
thanks
thanks
Post edited by fab on
i have never actually listened to the rm6000, but with the majority of sub satilite systems they are designed to have the satilites wired thru the sub , this is where the sats will get there crossover points this way they will not be running full range, as most can not handle the full range like a tower speaker..
i am sure that a few of the peeps on this forum that have similar systems will post in and give some advice and correect me if i am wrong.. also check the manual for proper wiring..
and welcome to the forum and the worl of polk :cool:Speakers:
Definitive BP7001sc mains
Definitive C/L/R 3000 center
Polk RT800i's rears
Definitive supercube I Sub
Audio:
Onkyo TX-NR3010
Emotiva XPA five Gen 3
OPPO BDP-103 CD, SACD, DVD-A
Video:
Panasonic TC-P65ZT60
OPPO BDP-103 Bluray
Directv x's 2 -
I don't know....my dad has the RM6600 system, and I hooked it through the sub amp. Doesn't it grab the lows from the center channel if youdo it this way? Parallel wiring would miss center lows, right? Even if a center is set to small, the LFE can't get re-sent to the fronts, right? I just used a monster sub cable for this, and the sound is virtually perfect.
John
