anyone ever repaired a sl2000 tweeter?
faster100
faster100 Posts: 6,124
edited July 2004 in Speakers
I went over Spasticpitbulls last night to bring my new tube amp and try on his new Monitor 10's.. well when he got the 10's one tweeter was blown so he got one from madmax.. while i was over there i took the broken tweeter home to play with, learn alittle, try and fix it. Ends up what was blown was the tiny wire leads that go from the coil to the terminals under that black silicone stuff on the front.. i removed that and sure enough the wires were gone... so i removed the dome/coil... resoldered a wire on each side of the coil, resoldered it to the terminals.. covered it with hot glue... and wammo.. it worked... Ive had it hooked to my rt25i's for the last few hours at medium volume.. sounds clear and doesnt distort. NOw i don't know if it will last, or sound degration issues as this was a project at best.. well anyways........ ive never heard anyone repairing them.. just replaceing them.. so heres a first maybe.
I'll post a pic of the completed tweeter later
MY HT RIG:
Sherwood p-965
Sherwood sd871 dvd
Rotel 1075 amp x5
LSI15 mains
LsiC center
LSIfx surround backs
Lsi7 side surrounds
SVS pb12/plus2
2 Channel Rig:
nad 1020 Pre-amp
Rotel 1080 stereo amp
Polk sda 2B
kenwood grunt Tuner
realistic lab 450 TT
Signal cable IC
  • faster100
    edited July 2004
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited July 2004
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • faster100
    edited July 2004
    and
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • madmax
    madmax Posts: 12,434
    edited July 2004
    Maybe you should start collecting broken ones and fixing them. I doubt polk will give you a job applying the black glue to their tweeters though. :D
    Vinyl, the final frontier...
  • faster100
    edited July 2004
    so has anyone fixed one? well that was my first try at it.. i would use silicone the next time if their were a next time.. I just used a sharpie and colored over the clear hot glue... :) couldnt get the weld look from the hot glue, lol
    MY HT RIG:
    Sherwood p-965
    Sherwood sd871 dvd
    Rotel 1075 amp x5
    LSI15 mains
    LsiC center
    Lsi7 side surrounds
    SVS pb12/plus2
    2 Channel Rig:
    nad 1020 Pre-amp
    Polk sda 2B
    kenwood grunt Tuner
    Signal cable IC
  • nadams
    nadams Posts: 5,877
    edited July 2004
